Discussion topic: Sky q mini won’t turn on
This message was authored by: beverleyr
Message posted on 04 Dec 2024 09:51 PM
Mini q won't come on
Find out more
Message posted on 04 Dec 2024 10:13 PM
Re: Sky q mini won’t turn on
Hi @beverleyr
Have you tried pressing the Standby button (Amber led) on the front of the mini box.
If this turns the min box on
With the Q box on with green led try completly resetting your mini Bluetooth remote.
Then make sure that you are pointing your remote at the mini and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
