Discussion topic: Sky q mini showing technical issue but can see Home Screen?
Message posted on 01 Jan 2024 09:00 PM
Recently moved mini q to new location and now can't see channels. Can see Home Screen and recordings but can't watch them. All settings been rebooted and connection to main box and internet all ticked. Get Technical Issue text on the screen. Not sure what more I can check? Any help welcome!
Message posted on 01 Jan 2024 09:02 PM
Re: Sky q mini showing technical issue but can see Home Screen?
Hi @Bushy10
Reboot the mini as above.
Message posted on 01 Jan 2024 09:18 PM
Thanks @oldfella
I've reset several times. I'm not on sky bb and connected via Ethernet.
I don't see the WPS option during set up as it goes straight to step 4 and connects to my router automatically
is there something I need to do in before rebooting? Signal from Q box won't reach location.many thanks
Message posted on 01 Jan 2024 09:24 PM - last edited: 01 Jan 2024 09:24 PM
@Bushy10 wrote:
Thanks @oldfella
I don't see the WPS option during set up as it goes straight to step 4 and connects to my router automaticallyis there something I need to do in before rebooting? Signal from Q box won't reach location.many thanks
What is connected by Ethernet and to what @Bushy10 ?
Message posted on 01 Jan 2024 10:09 PM
@oldfella Internet into Ethernet splitter. Main box into Ethernet splitter. Ethernet link from splitter to an access point and then mini from the AP!
Message posted on 01 Jan 2024 10:13 PM
Message posted on 01 Jan 2024 10:29 PM
Thanks @oldfella
it is 'hard wired' from the AP. Presume this is same as WiFi? Will Q booster help even though I don't have sky BB?
thanks again
Message posted on 02 Jan 2024 09:01 AM - last edited: 02 Jan 2024 09:02 AM
No, not the same as wifi
Was it connected like that before?
is wifi disabled on the Q and mini?
Message posted on 02 Jan 2024 10:21 AM
@Bushy10 wrote:
Thanks @oldfella
thanks again
Hi @Bushy10
You say
If you have Ethernet from Switch to Access point and also Ethernet from mini to Access point how are both Ethernet cables connected to the AP?
Message posted on 02 Jan 2024 02:35 PM
Hi @Chodley haven't turned Wi-Fi off on either. It was connected via power line before. I've tried in new room and the power line is working (thought it was on different ring main but obvs not). Bit jerky tho. Will turning Wi-Fi off allow me to use router (being used as WiFi booster) in new room?
many thanks
Message posted on 02 Jan 2024 02:38 PM
Hi @oldfella
@I've set up a router in new room but using it as booster for WiFi. It has rj45 sockets and I've used one of them for mini box. It is connected via Ethernet to the 'main' router
many thanks
Message posted on 02 Jan 2024 06:40 PM
It'll stop the mini deciding to try wifi for the fun of it.
Message posted on 02 Jan 2024 06:55 PM
@Bushy10 wrote:
Hi @oldfella
many thanks
Hi @Bushy10
Your connections are too diversified.
if your main Q box is connected by Ethernet to your Router then it's best to connect the mini by Ethernet to your router.
This should be quite simple if have the router/booster connected by Ethernet and also have the mini connected by Ethernet to the booster router. Just forget about the booster router and connect the two Ethernet cables together..
if you have all Q boxes connected to your main router by Ethernet then you can then switch off all Q box WiFi.
Start with main Q box and first carry out a Network reset with the Ethernet connected.
Highlight Status and then select Reset on the right hand side. Select connect wired to non Sky Router (or Sky router if on Sky Broadband). Do not carry out any WPS and just wait for the box to connect. It may take a couple of minutes. If it does not connect there is an issue with the Ethernet connection.
Immediately as soon as it connects go into the Q box hidden menu and turn off WiFi.
Go to Network to turn off both bands of WiFi. Confirm before exit.
Repeat the network reset on any minis in the Mini Home menu with the Ethernet connected. Again do not do any WPS and just wait for it to connect.
Once it is connected go immediately into the mini hidden menu (same procedure as above) and turn off both bands of WiFi. Confirm before exit.
Message posted on 02 Jan 2024 09:05 PM
As long as the networks are bridged the physical layer doesn't matter. In theory.
What won't work is the sky self-managed mesh on wifi (non-skybb) with a mini trying to join it via ethernet to the router.
