Discussion topic: Sky q mini keeps disconnecting from sky q box
Message posted on 11 Nov 2024 04:09 PM
The sky q mini box keeps disconnecting from the main box, but it says it is connected on the main box.
im having to restart the sky q mini box about 3/5 times a day as this is happening regularly.
i have also reset the broadband but the same thing keeps happening.
then yesterday, the remote also started to lose connection and I now need to reset the sky q mini remote to the sky q mini box - I have had to do this twice.
is this something that can be fixed?
thank you
Message posted on 11 Nov 2024 04:18 PM
Re: Sky q mini keeps disconnecting from sky q box
thank you
Hi @bopit118
Reboot the mini as above.
Message posted on 11 Nov 2024 04:29 PM
Thank you, I have tried all these steps before but will try again.
i have had the sky q and sky mini, along with the same non sky broadband working fine without problems for the past 3 years.
All our other devices are connected without issue/internet is working fine
thank you though
