This discussion topic has been answered Discussion topic: Sky q mini has an 'accessibility on sky q' message
Message posted on 28 Jan 2025 07:27 PM
It has two options - Settings or Skip& set up later, but I can't select any of the options to get past this screen
Message posted on 28 Jan 2025 07:39 PM
Sky have suggested the following...
- Unpair their Sky Q remote from the box by holding 4&6
- Wait for the remote to flash
- Then dismiss the information screen "Skip & set up later"
- Hold 1&3 to repair the remote control
If 4&6 does not allow you to clear the information screen, try holding 7&9 to reset the Sky Q remote then hold 1&3 and follow the on-screen setup journey to allow the remote to control the TV.
Re: Sky q mini has an 'accessibility on sky q' message
hi @Hoorse
This message seems to have caused a bit of a quirk so try this:
Press & hold 4 & 6 on the remote to set to Infrared only
Hopefully you can then dismiss the message
Then try re-pairing in bluetooth mode with the box by pressing & holding 1 & 3 together
If this does not work try a full remote reset by pressing & holdng 7 & 9 until the red led above the SKY logo button flashes 4 times
Then try the 1&3 to re-pair & pair with the TV
Message posted on 28 Jan 2025 08:12 PM
Thank you so much
That solution was spot-on, easy to follow, and importantly - it worked a treat.
Thank you @Daniel0210
