3
Discussion topic: Sky q mini has an 'accessibility on sky q' message
28 Jan 2025 07:27 PM
It has two options - Settings or Skip& set up later, but I can't select any of the options to get past this screen
28 Jan 2025 07:39 PM
Posted by a Superuser, not a Sky employee. Find out moreSky have suggested the following...
- Unpair their Sky Q remote from the box by holding 4&6
- Wait for the remote to flash
- Then dismiss the information screen "Skip & set up later"
- Hold 1&3 to repair the remote control
If 4&6 does not allow you to clear the information screen, try holding 7&9 to reset the Sky Q remote then hold 1&3 and follow the on-screen setup journey to allow the remote to control the TV.
▪️I AM NOT A SKY EMPLOYEE (undercover or otherwise) ▪️
