Discussion topic: Sky q mini disconnected AGAIN
This message was authored by: Middie
Every night my sky q mini is disconnected from the main sky box. Every night I have to go down and reset the main box, then reset the mini hoping it will connect. Getting very annoying as this time it won't connect. Gone into settings and reactivated it's that not working either. Good old sky, internets terrible now this. Good job I m only paying £100 a month
Re: Sky q mini disconnected AGAIN
Hi @Middie
Have you carried out a Network reset on the mini to reconnect it?
