Discussion topic: Sky q mini boxes not showing any picture just blue screen saying no satellite signal
Message posted on 09 May 2023 08:27 PM
Sky q mini boxes not showing any picture just blue screen saying no satellite signal but is connected to both internet and main Sky Q box. Have rest all about 4 times
Message posted on 09 May 2023 08:34 PM
Re: Sky q mini boxes not showing any picture just blue screen saying no satellite signal
@DesDoc Have you tried rebooting your main Q box ie
then
rebooting your mini box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 09 May 2023 11:48 PM
Thanks for replying. I solved the issue but it meant resting the hard drive which wiped all the recordings. I noticed I Couldn't pause or rewind live Tv or access recordings and message about an issue with the hard drive showed so I had to go into the hidden settings using 001 select and reset the drive which was full to capacity which must be the reason for the issue in the first place. . All now working again.
