Discussion topic: Sky q mini box won’t connect to WiFi
Message posted on 21 Jul 2024 09:08 PM
Hi, my mini sky Q box will not connect to the WiFi "no satellite signal" everything was fine until about 2-3 weeks ago and I have had a problem with it for a while. Please can an advisor contact me
Message posted on 21 Jul 2024 09:10 PM
Re: Sky q mini box won’t connect to WiFi
Hi @Tracey2024
Afraid you are not contacting Sky directly here as this is a customer forum.
If you need to contact them you need to persevere by phone.
To contact Sky
Select Need more help
at the bottom of the following link and this will lead to a phone contact.
Ignore all automated messages and wait for an agent
https://www.sky.com/help/home
Regarding your issue
Reboot the mini as above.
Message posted on 23 Jul 2024 10:24 PM
Hi Tracey,
Oddly I have the same issue... Have had my Sky Q mini box working perfectly fine off of my BT Broadband (also have a WiFi disc booster thing in the same room), but for some reason a couple of days ago I suddenly got the error that it wasn't connected to the WiFi.... The only way I've got mine working now is by plugging an ethernet into the back of the box, but unfortunately as soon as I unplug it the connection is gone.
