This discussion topic has been answered Discussion topic: Sky q mini box stuck on step 1 of 4 following new EE router being installed
Message posted on 26 Jan 2024 05:09 PM
New full fibre EE router installed today and main sky q box and booster now are working correctly. Sky q mini box however when switched on will not go past step 1 of 4 of set up.
Mini box has been disconnected and reconnected, also reset without success. Any ideas?
Message posted on 26 Jan 2024 07:24 PM
Thanks for response.
Sky tech said mini needed replacing but would be 10 days at earliest.
I decided nothing to be lost, so pushed WPS button on mini and it immediately progressed through steps 1 to 4. However, remote had no effect until I re-synced it to mini.
Now Sky mini box working well!
Message posted on 26 Jan 2024 05:18 PM
Re: Sky q mini box stuck on step 1 of 4 following new EE router being installed
Full factory reset?
Message posted on 26 Jan 2024 11:15 PM
So you'd already pressed the WPS button on the other box? But that on its own didn't work? It's supposed to trigger it in software from the mini you're trying to connect without needing to press its own button.
Very interesting.
