Discussion topic: Sky q mini box stuck on standy and will not turn on
This message was authored by: Lambretta1984
My sky q mini box has been on standby for weeks, and no matter what I try to do, it will not turn on at all. We have tried everything advised from SKY and nothing appears to be working. Just told to order a replacement box but has no information on if this is a cost to me. When I go to order a replacement one, it just asks to submit the order, nothing about costs. Do i assume this is free as the box is not working?
Re: Sky q mini box stuck on standy and will not turn on
@Lambretta1984  As they are Loaned to you there is no cost to replace faulty boxes.
Hi @Lambretta1984
Assume you have tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Failing this replacement for faulty Sky Q boxes is at Sky's expense as they are all rented.
