Discussion topic: Sky q mini box on red not connected to new router
This message was authored by: tulipsat68
Just had a replacement router not Sky .  Updated Sky q box ok and connected . Small q box is on red and I can't get it to connect.
Re: Sky q mini box on red not connected to new router
@tulipsat68 firstly Try resetting your remote.
Press the buttons 7 & 9 together on the remote until it’s led flashes four times.
Then press 1 & 3 together until the led flashes twice then follow onscreen instructions to repair the remote.
If the above doesnt work have you tried pressing the red light as this is also a button you need to turn on your mini box ie light going to green  to connect it to the main box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
