Discussion topic: Sky q mini box not turning on, the light is staying amber. Tried the 7&9/1&3 deal and tried rebooti.
This message was authored by: L.j
Sky q mini box showing only amber light. Nothing on screen. Tried 1&3/7&9 button thing and nothing. Tried reboot, still nothing
Re: Sky q mini box not turning on, the light is staying amber. Tried the 7&9/1&3 deal and tr
@L.j try pressing where the amber light is as its also the on button see if the box comes on if it does then try resetting your remote
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for L.j
Thanks, already tried that; still blank screen with no green light
@L.j have you tried pressing the reset button on the back of the mini box hold it in for 20 seconds
Hi @L.j
If the following link does not fix your issue you need to replace your mini
https://www.sky.com/help/articles/sky-q-box-wont-turn-on#:~:text=Restart%20your%20Sky%20Q%20box,back....
Avatar for L.j
All sorted, thanks
