Discussion topic: Sky q mini box locks every day
This message was authored by: Chris5710
Every morning when I want to use the sky mini in the kitchen  it refuses to switch on
The light just stays red
If I unplug it for a few mins and plug it back in it then resets itself and works fine until the next morning
I have to reset it every day
help please
Re: Sky q mini box locks every day
Maybe faulty. I'd use the box troubleshooter to get a replacement.
Avatar for Chris5710
Level 0 icon
I tried this but it asks if a reset works - which it does - and then it assumes all is ok and ends the process 🤦🏻‍♀️
Hi @Chris5710   What time in the morning? To rule out the standby settings. The light should not be red (in power saving mode), it should be amber (standby mode).
Would be a shame if that didn't work after all
