Discussion topic: Sky q mini box freezing. Also not playing recordings properly and can't exit recordings
Message posted on 09 Jul 2025 08:55 PM
I think my sky q mini box is terminal. It just doesn't do what I want ot to. It has developed a mind of it's own. Can't fast forward then when it does I can't stop it. When I play a recording I can only exit it when full recording has played. I have switched it off and reset it.
Message posted on 09 Jul 2025 08:59 PM
Re: Sky q mini box freezing. Also not playing recordings properly and can't exit recordings
@CATHYV wrote:I think my sky q mini box is terminal. It just doesn't do what I want ot to. It has developed a mind of it's own. Can't fast forward then when it does I can't stop it. When I play a recording I can only exit it when full recording has played. I have switched it off and reset it.
If you have completed the reset talked about here: https://www.sky.com/help/articles/sky-box-problems
Then you should be able to select "that didn't work" or "I still need help" at the bottom of the page to get a number and call Sky for a replacement, further assistance or perhaps even an engineer visit.
LG B6 OLED 55” | LG UP75 LCD 43” | Sky Q | Sky Q Mini | Sky Soundbox | EE Apple TV 4K | EE Full Works FTTC
Message posted on 09 Jul 2025 09:05 PM
Thank you I will try that.
