Discussion topic: Sky q mini box does not turn on post sky max hub installation
This message was authored by: Frank__28
Hi Turned on my minibox this morning. It couldn't connect to the network. So selected re setup. Now the box doesn't turn back on. Despite multiple unplugging. Just a dormant red light
Re: Sky q mini box does not turn on post sky max hub installation
Hi @Frank__28
Have you tried pressing the Standby button (Amber led) on the front of the mini box.
If this turns the mini box on
With the mini box on with green led try completly resetting your mini Bluetooth remote.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
Reset the remote so it uses infrared mode.
7&9 if I recall correctly for about 4-5 seconds.
You'll also have to connect the mini direct to the Q with that hub I think
