Discussion topic: Sky q mini box connected to sky q but gives message “there is a technical fault with this channel”
Message posted on 16 May 2023 07:03 PM
I have two mini boxes connected to sky q. In settings it has two ticks. I am able to watch Netflix and other apps. I just can't watch any sky programmes. I get the message "there is a technical fault with this channel. Please try again later " I think the issue is to do with the ip address. Can anyone suggest a solution please?
Message posted on 16 May 2023 07:21 PM
Re: Sky q mini box connected to sky q but gives message “there is a technical fault with this channe
Hi @SJW+1
Reboot the minis as above.
Message posted on 16 May 2023 08:00 PM
Thanks for the suggestion. I had already done this and just did the restart again. Unfortunately it's the same result. The mini box is connected to the sky q box and the network. We can access all of the apps eg Netflix , prime , iPlayer just not the sky channels. Any other suggestions or thoughts? Thanks
Message posted on 16 May 2023 08:06 PM
Who is your Broadband supplier @SJW+1 ?
Message posted on 16 May 2023 08:10 PM
Sky broadband
Message posted on 16 May 2023 08:13 PM
Message posted on 16 May 2023 08:20 PM
Ah ordinarily we could except that the boxes are connected by Ethernet cable. We live in a farm and use Ethernet to distribute wifi and sky into an outside building
Message posted on 16 May 2023 08:23 PM
Message posted on 16 May 2023 08:48 PM
The main sky q box in the house connects by wps. The two mini boxes connect via Ethernet. The odd thing is that until last week it worked perfectly. We do not know what has happened but it's not working now.
Message posted on 16 May 2023 08:51 PM
Message posted on 16 May 2023 10:53 PM
Firstly thanks for the time you've spent trying to help. I could try and link the main sky q box by Ethernet but what I don't understand is why I can watch bbc iPlayer through the mini box but not the sky programmes. Does that make any sense?
Message posted on 12 Jun 2023 09:41 PM
Any resolution to this got same problem
Message posted on 22 Jul 2023 09:42 PM
Same issue here sky mini box (technical fault) but everything else ok have tried all the resets and rebooting been on it now for last 4 hours 🙈 trying different things but still no luck 🙈
Message posted on 22 Jul 2023 10:37 PM
Having the same issues. I live in Chelmsford, Essex if that's at all relevant to anyone.
Message posted on 28 Oct 2023 08:01 PM
My sky q box works perfectley on everything,
however,
My sky mini box works on everything but the red button match choice or recap where it comes up with the message "there is a technical fault please try later", and the code LAY 1 or more recentley DUG 1 sometimes with an id code underneath which is different every time.
Is there anybody on the planet who know what these codes mean?
I have had two mini boxes, two sky q boxes and an engineers visit and still it is the same, another engineer is due on the 7th November.
Sky technical knowledge seems to be limited to reboot or reset both boxes, which is useless!
I have tried every conceivable method of connection both wired and wifi, nothing makes a difference
I am beginning to believe he problem is at sky's end
