8
This discussion topic has been answered Discussion topic: Sky q is non responsive when going to menu taking 5 to 10 minutescto connect to a station or drops c
This message was authored by: Nicola2001
Sky q is non responsive when tv menu is displayed. Unable to scroll to different channels or manually change plus get eeror messages unable to connect
Re: Sky q is non responsive when going to menu taking 5 to 10 minutescto connect to a station or dro
Hi @Nicola2001
Avatar for Nicola2001
Level 0 icon
TV goes blank for a while whilst changing channels & takes ages to get to selected channel
Hi @Nicola2001
Level 0 icon
We have done all this & is still not working
Level 0 icon
Can I speak to an agent please
Hi @Nicola2001
Afraid you are not contacting Sky directly here as this is a customer forum.
If you need to contact them you need to persevere by phone.
To contact Sky
Select Need more help
at the bottom of the following link and this will lead to a phone contact.
Ignore all automated messages and wait for an agent
https://www.sky.com/help/home
This message was authored by: Daniel-F
Posted by a Sky employee
Hi @Nicola2001
I’ve escalated your post to Sky and the Messaging Team may get in touch with you later.
Look out for a blue/red speech bubble at the bottom of your forum page. You’ll then have 48 hours to click on it and join the private chat or it will close automatically. If you fail to respond to each chat reply within 48 hours the chat will again close down automatically even if your issue hasn’t been resolved. Replies from Sky aren’t instant so you’ll just need to check the chat thread regularly.
This link explains the Community Messaging process.
Daniel
Community Moderator
This message was authored by: Addie15
Hi there! Thank you for escalating this. We have sent an invite @Nicola2001.
This message was authored by: Lisa-P1987
We are still looking to help you @Nicola2001 . If you need our support let us know and we can re-escalate to our chat team. Your invite has been closed now. Thanks
Lisa - Sky Tech Team Expert
