Discussion topic: Sky q installed today on demand and catch up not working
This message was authored by: Nik5
Tried everything that has been suggested on previous posts with no luck.
Re: Sky q installed today on demand and catch up not working
Hi @Nik5   "Not working" is too vague, we really need details of error messages, missing apps etc. I would make sure that you are on the latest software Q220 (or Q230). Look in System info under Settings.
@Nik5 Sky signature comes with live TV, catchup and boxsets.in SD as standard you may be trying to download the programme in HD
The default download setting is HD so try changing the format to download in SD
you can change the default to SD by Pressing Home on your Sky Q remote and select Settings, then Setup.
Select Preferences, then 'On Demand default download format', and choose SD.
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for Nik5
No catch up or online programmes to download.  Only the 1 most recent showing.
