8
This discussion topic has been answered Discussion topic: Sky q in converted garage
This message was authored by: Ben90
Hello all. I have converted my garage and wish to extend my Sky q to the garage . it is around 50 feet from the house. Would a sky q mini box work out there?
Avatar for Ben90
This message was authored by: Ben90 Answer
Re: Sky q in converted garage
Thanks @TimmyBGood and @oldfella
Very helpful comments and my questions answered. Very grateful to you both
@Ben90
WiFi may well be a problem, particularly if the conversion used foil-laminate foam insulation boards.
Avatar for Ben90
Thanks for your response.
I was actually thinking of running the main Sky q box from the converted garage. Would the 3 miniboxes in the house be able to connect from around 50 feet away on the bluetooth.
@Ben90
Same problem either way (although it's WiFi, not Bluetooth)
Remember that it's the main Q box which requires the dish feed cable.
Hi @Ben90
Looks like you need exterior grade Ethernet from your Main Q box to the Garage.
Avatar for Ben90
Yes I was planning to feed the satellite cable into the garage. So if it is all run by WiFi would a good WiFi extender do the trick
Hi @Ben90
Afraid WiFi will not reach.   Only Q WiFi extenders will work with Sky Q
As I said you will need to run Ethernet cable between your garage and your house.
I'd suggest if you are running satellite cable then adding an ethernet run would seem sensible.
Avatar for Ben90
