Discussion topic: Sky q has no internet connection
This message was authored by: Garry72
My sky q box keeps losing internet connection with my new virgin broadband. I've tried numerous times to reconnect. It connects for 10 seconds then loses it again. Any ideas
garry
This message was authored by: Addie15
Re: Sky q has no internet connection
Hi there,  @Garry72. I’ve escalated your post to our Community Messaging team who will invite you to a private chat shortly and help you with this.
garry
Hi @Garry72 Try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on?
@Garry72 wrote:
. Any ideas
Yeah. Don't use wifi.
This message was authored by: 1000+Cutts
Welcome to the highly irritating world of Vodafone broadband and SkyQ. My bedroom box drops all the time
@1000+Cutts your bedroom mini box doesn't connect to your vodafone broasdband it needs to connect to your Sky Q main box
Update-We are closing this invite now due to no response within 48 hours. If you still need help, please let us know so we can re-escalate this for you. Thanks.
This message was authored by: Chris-in-SBS
Hi @Garry72, I'm having the same issue.
I've switched off my Sky box to reboot it, reset multiple times & reset my router but still not fixed.
Have you fixed your issue, & how did you fix it?
Cheers
Chris
