Discussion topic: Sky q freezing up and going blank, unresponsive until restart
Message posted on 15 Jul 2023 03:04 PM
I am having lots of problems with my sky q box over the last few days.
It freezes up with a blank screen.
I keep having to unplug and restart it.
then it takes ages for the thumbnails to appear, channel changing is very sluggish, eventually not responding at all. The next day again it all freezes up and I need another restart.
any ideas? I have no issues with my broadband or satellite, the box itself thinks everything is ok if I check under settings. The app doesn't see any issues.
Could the software be corrupt?
Message posted on 15 Jul 2023 03:12 PM
							Re: Sky q freezing up and going blank, unresponsive until restart
Hi @Vbs
Message posted on 16 Jul 2023 10:25 AM
Thanks so much for this.
It does seem better after the settings reset.
I haven't had to restart it today.
I'll see how it goes.
Message posted on 24 Jul 2023 07:39 PM
Still got lots of issues with this.
the tv channels go blank and changing channels becomes unresponsive the next day, and again I have to power off and on. It sometimes says there is a technical fault with any channel I'm trying to view.
Even video playback like Netflix and YouTube is affected (no playback) until I reboot.
should I just call customer support?
I have had this box for years but this persistent problem only started a couple of weeks ago.
Message posted on 16 Feb 2024 04:44 PM
I'm having the exact same issues
did you ever get a resolution to this please
Message posted on 01 Mar 2024 08:38 PM
Any luck resolving this? Also getting the same issue. Must be a fault with some boxes? Very annoying as sky can't come out for another week 🙄
Message posted on 01 Mar 2024 08:45 PM
I have been too lazy to report it to Sky yet.
It got better on its own in that I no longer need to restart the box daily. I didn't do anything special.
The box in general is not super responsive.
