Discussion topic: Sky q fitted downstairs have now lost freesat on tvs upstairs
Message posted on 01 Oct 2024 05:17 PM
Have just had sky q fitted downstairs have now lost freesat on tvs upstairs
Message posted on 01 Oct 2024 05:21 PM
Re: Sky q fitted downstairs have now lost freesat on tvs upstairs
hi @refinery
Unfortunately SKY Q uses a different LNB to Freesat
To use both SKY Q and Freesat you need what is called a Hybrid LNB but ubfortunately SKY stopped installing these a while ago.
You may be able to get a local installer to install one
Message posted on 01 Oct 2024 05:22 PM - last edited: 01 Oct 2024 05:22 PM
FreeSat (Via dish) or FreeView (Via aerial)?
Message posted on 01 Oct 2024 05:26 PM
Hi @refinery
If you are referring to Freeview and you have a terrestrial aerial there is not any RF (terrestrial outputs ) on Sky Q so you will have lost the ability to use the Q box for RF out.
You will need to buy a simple powered aerial splitter to take the input from your terrestrial aerial and feed it to your main TV and also to the other Televisions.
Something like the following
Message posted on 01 Oct 2024 05:27 PM
BTW @refinery I have removed your duplicate post
