Discussion topic: Sky q failing to record properly
This message was authored by: Simon1999999998
My box records programs but they are always corrupted, the play back pauses and is distorted as well as the message " Software Issue" displayed on the recording description, anyone have any ideas
Re: Sky q failing to record properly
@Simon1999999998
Probably hard drive-related: if you log a fault with Sky they will swap the box out by courier.
Remember to remove the viewing card before handing the box over.
Avatar for Simon1999999998
Thank you I will give that a go.
