Discussion topic: Sky q connecting to the wrong WiFi network
This message was authored by: Mf9
My sky q mini box is connecting to the wrong WiFi network
Re: Sky q connecting to the wrong WiFi network
Hi @Mf9
Sky Q minis can only connect to what you tell them when you reset their Network.
Reboot the mini as above.
