27 Apr 2023 09:55 AM
After years with no issues, now won't connect. Everything else in the house is still connected. Tried all 3 types of resets and still says unsuccessful and due to password. The password is correct.
27 Apr 2023 10:52 AM
Hi @Kirsten562
Assume you tried a Network reset on the Q box?
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
27 Apr 2023 12:51 PM
Yes, I've done all of that and tried a couple of times
27 Apr 2023 12:59 PM
Hi @Kirsten562
Assume you are on 3rd party broadband.
Who is the provider?
27 Apr 2023 03:02 PM
Virgin media. No issue with connectivity of any other device in the house
02 Sep 2023 10:11 AM
Hello, I have exactly the same problem and I am on virgin media. Every other device works in the house as is the smart TV itself, but the sky Q box refuses to reconnect after a full reset process. Did you eventually find out how to resolve this I would be keen to know thank you
Jonathan
