Discussion topic: Sky q box won't connect to talk talk broadband
This message was authored by: Kirstyf2
I have been having issue connecting sky w to talk talk WiFi. This has been ongoing for a few days. I have tried resetting the box and resetting the wifi but nothing that I am doing seems to be working. This is affecting the main box which we have had for years, and the multi room box that we have which is about a month old.
Re: Sky q box won't connect to talk talk broadband
Hi @Kirstyf2
On 3rd party broadband and your router does not have a reset button, reboot it by disconnecting the power lead for 30 secs and then reconnecting.
On 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
Avatar for Kirstyf2
It's coming up that there is a problem finding the sky q box on the network
