Discussion topic: Sky q box won’t connect to internet
Message posted on 08 Jun 2024 03:12 PM
Sky box won't connect to internet but the sky box in another room works fine
Message posted on 09 Jun 2024 08:58 AM
Re: Sky q box won’t connect to internet
Hi there @PennyTaylor , I’ve escalated your post to our Community Messaging team who will invite you to a private chat shortly and help you with this.
Message posted on 09 Jun 2024 09:28 AM
Hi @PennyTaylor Try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on, then do the same with any Mini boxes?
Message posted on 11 Jun 2024 09:14 AM
Hi @PennyTaylor
An invite was sent but there was no response within 48 hours so it has automatically closed.
If you still need help with this please let us know by posting on the forum again and we will get it escalated through to us.
Tom
Message posted on 11 Jun 2024 11:22 AM
Hi non of my Q box,s Will connect to the internet, But everything else works?
Message posted on 12 Jun 2024 12:25 PM
Re: Sky Engineer
I need to book an engineer please
Message posted on 12 Jun 2024 12:30 PM
Re: Sky Engineer
Have you rebooted your router as suggested above? Then try a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if necessary-
~ press the 🏠 button
