Discussion topic: Sky q box won’t connect to internet
This message was authored by: Adam44
Sky Q box won't connect to internet
Re: Sky q box won’t connect to internet
Going to need a little more to go on
Hi @Adam44
Assume this is your Main Q box.
Try a Network Reset found in Q box Home - Settings - Setup - Network.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
Avatar for Adam44
Hey how do I enter SSID number?
Using your remote control @Adam44
And you can use the number keypad like an old nokia mobile for quick entry
