29 Sep 2023 09:56 AM
Sky Q box won't connect to internet
29 Sep 2023 10:47 AM
Posted by a Superuser, not a Sky employee. Find out moreGoing to need a little more to go on
29 Sep 2023 11:02 AM
Hi @Adam44
Assume this is your Main Q box.
Try a Network Reset found in Q box Home - Settings - Setup - Network.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
29 Sep 2023 11:05 AM
Hey how do I enter SSID number?
29 Sep 2023 11:43 AM
Posted by a Superuser, not a Sky employee. Find out more29 Sep 2023 12:27 PM
Posted by a Superuser, not a Sky employee. Find out moreAnd you can use the number keypad like an old nokia mobile for quick entry
