Discussion topic: Sky q box will not connect to my broadband
This message was authored by: Dawnie90
I have broadband with Vodafone and every other device even my tv itself connects fine to the internet. However, the sky q box just will not connect please can anyone help? I have tried resetting my sky q and my broadband router. I unfortunately cannot connect via Ethernet as they are in different rooms of the house. Thanks
Re: Sky q box will not connect to my broadband
Hi @Dawnie90
Try a Network reset.
On 3rd party broadband and your router does not have a reset button, reboot it by disconnecting the power lead for 30 secs and then reconnecting.
On 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
