Discussion topic: Sky q box stuck on accessibility page
Message posted on 09 Feb 2025 07:14 PM
My sky q box is stuck on accessibility page and won't recognise the remote control. Rebooting hasn't helped
Message posted on 09 Feb 2025 07:16 PM
Re: Sky q box stuck on accessibility page
This message seems to have caused a bit of a quirk so try this:
Press & hold 4 & 6 on the remote to set to Infrared only
Hopefully you can then dismiss the message
Then try re-pairing in bluetooth mode with the box by pressing & holding 1 & 3 together
If this does not work try a full remote reset by pressing & holdng 7 & 9 until the red led above the SKY logo button flashes 4 times
Then try the 1&3 to re-pair & pair with the TV
Message posted on 09 Feb 2025 07:23 PM
No joy I'm afraid 😞
Any other suggestions gratefully received
Message posted on 09 Feb 2025 07:33 PM
Hi @Shifnal+home Try 7 & 9 until you see 4 flashes. The box must be in line of sight (not hidden).
Message posted on 09 Feb 2025 07:35 PM
Does this take a certain length of time? Have tried but no red flashes (with box in sight)
Message posted on 09 Feb 2025 07:38 PM
Hi @Shifnal+home Hold down 7 & 9 until the LED on remote flashes four times. Try pressing the "?" key (LED should light up) to check that the remote is not dead.
Message posted on 09 Feb 2025 07:58 PM
@Shifnal+home try the following...
reboot the Q box in question
then
Unpair their Sky Q remote from the box by holding 4&6
Wait for the remote to flash
you should then be able to dismiss the information screen by clicking on Skip & set up later
Hold 1&3 to repair the remote control
If 4&6 does not allow you to clear the information screen, try holding 7&9 to reset the Sky Q remote then hold 1&3 and follow the on-screen setup journey to allow the remote to control your TV.
Message posted on 01 Mar 2025 12:37 PM
Exactly the same problem. None of the suggestions works.
