Discussion topic: Sky q box reset every day
Message posted on 10 Oct 2024 10:00 PM
Sky q is getting worse. Resorting to resetting sky q box every day to connect properly to Internet to receive Home page/apps etc. Do all the usual as previously had issues and it just seems to be fine for a bit then have yo rest on a daily basis. Fèl like cancelling all together and raising an issue with ombudsman as definitely not worth £108 a month, shocking!!
Message posted on 10 Oct 2024 10:03 PM
Re: Sky q box reset every day
To reset and fine for a bit (update pre-text)
Message posted on 11 Oct 2024 01:48 PM
I am having the same problem with my sky Q boxes. They are constantly losing the internet connection which means they need resetting every time. It's happening every day more then once. I have checked my broadband router and the WiFi signals but everything is working as normal. I have seen this problem on other forums but nobody seems to have an answer.
Message posted on 11 Oct 2024 04:23 PM
To be honest, seems fine in the morning then afternoon/evening you lose Home screen/apps etc until you turn box off. Sky q must be the worst thing that sky brought out!!!! Will have to make an official complaint and get out of this never ending headache 😞
Message posted on 14 Oct 2024 08:48 AM
Check your Standby mode, if it is Eco or None change it to Active. This MIGHT solve your problem. Go to settings, then Setup, then Preferences.. On the right look at Standy Mode. If it is not set to Active then that might be your problem. Worth a check methinks, it might fix your problem.
Message posted on 14 Oct 2024 03:44 PM
In Eco, set to active, will give it a bash, thanks.
Message posted on 14 Oct 2024 10:12 PM
I tried this on my boxes earlier and it lasted 10 minutes before losing signal again.
Looks like I'm going to have to waste a few hours tomorrow trying to contact Sky about it
Message posted on 16 Oct 2024 11:43 AM
Tried resetting box to active, made no difference. Last 4 months or so is getting worse, fed up turning it on and off every day. Sky need to get a grip with many customers having issues with this and paying for a service we are clearly not getting.
