Discussion topic: Sky q box not staying connected to boardband
Message posted on 14 Apr 2024 10:31 AM
Message posted on 14 Apr 2024 10:42 AM
Re: Sky q box not staying connected to boardband
Hi @kai1603
Try completely resetting the connection as follows.
