Discussion topic: Sky q box not linking with Wi-Fi
This message was authored by Barryw3885 This message was authored by: Barryw3885
Sky box won't connect to Wi-Fi
This message was authored by idol+the+bear This message was authored by: idol+the+bear
Re: Sky q box not linking with Wi-Fi
If you have Sky broadband reboot your Sky router by pressing the button on the back of the router and then get your Q box to search for your WiFi network which should now show and you can then connect to  it.
This message was authored by Laing1 This message was authored by: Laing1
@Barryw3885 who is  your internet provider ?
This message was authored by PT1971 This message was authored by: PT1971
I have the exact same issue. Its happened twice now in 4 weeks. Last time I was on phone to Sky for over an hour (almost as long as the time I spent going round in circles on the website). I've tried rebooting the Sky Q box and also the router (which is Sky).
Everything else in the house is pairing with WiFi on full signal so it has to be a Sky Q box issue.
Been waiting in queue for 25mins - lines close at 9pm so won't be working overnight.
Hi @Barryw3885
@PT1971
Try a Network Reset found in Q box Home - Settings - Setup - Network.
This message was authored by Kysha1993 This message was authored by: Kysha1993
I'm having this issue also I'm eveything in my home is paired with the WiFi but both my sky boxes won't
This message was authored by Chodley This message was authored by: Chodley
Start again from scratch
all sky boxes and any booster and router off
Router on. Wait 10 minutes.
If you have a booster, connect that to the router using the WPS button.
Turn the Q on (only the main one)
Reset network. WPS buttons if it's a sky box or booster. Wifi ssid and passcode if it's a 3rd party router.
If that works, you can do the minis
If it doesn't, do what I did and ditch wifi.
Similar approach (but does a full reset on the Q settings, without losing recordings, not just a network reset) and only for Sky router
https://helpforum.sky.com/t5/Sky-Q/Broadband-not-connecting-to-sky-Q-box/m-p/4503692
Barryw3885
Thanks - all fixed
Thanks everyone. All sorted!
All sorted thank you x
This message was authored by JudeT This message was authored by: JudeT
Having the same issue since changing to go fibre. Did you find a fix?
Try the process in post 2 above.
They said they were on GoFibre so the Sky BB approach won't work.
