Discussion topic: Sky q box no picture . Cables and sockets all fine reboot done and switched off at mains o
Message posted on 01 Jun 2023 07:40 PM
Full reset done on sky q box and still no picture.
Message posted on 01 Jun 2023 08:17 PM
Re: Sky q box no picture . Cables and sockets all fine reboot done and switched off at mains o
Hi @helenfb
If you have a green light on your Q box and you are sure that the HDMI TV input on the TV is set correctly for your Q box
Then try pressing
Home 1 0 8 0 Home
on the Q remote.
This will set the mini to 1080i resolution.
If you don't have a green led
Have you tried switching the Q box on by pressing the Standby button on the front right of the Q box (the Amber Led)?
If this brings the box on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
