Discussion topic: Sky q box needs numerous resets as it keeps getting stuck
Message posted on 29 Oct 2025 10:02 AM
For the past week I'm having to reset the q box numerous times each night. The programs are stuttering and I have to reset to watch . It must be the box as it is on all programs when it happens
Message posted on 29 Oct 2025 05:32 PM
Re: Sky q box needs numerous resets as it keeps getting stuck
@Terri+Jackson You could try resetting the settings in the Q boxes hidden menu.
To enter the hidden menu press the home button and scroll down to settings but do not select settings.
With settings highlighted press 0 0 1 then select
Only Carry out the first Reset being Reset Settings as the others will wipe all recordings.
After the reset you will have to re-pair your remote assuming you are using a bluetooth remote by pressing 1 and 3 together on the remote
If that doesn't work then you will have to contact sky for a replacement box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
