Discussion topic: Sky q box losing connection to tv after a couple of minutes - tv works fine
Message posted on 22 Dec 2024 12:49 PM
My sky q box appears to be disconnecting from the tv randomly - it will work for a few minutes and then screen goes blank, tv works fine just connected to internet on its own
Message posted on 22 Dec 2024 01:02 PM
Re: Sky q box losing connection to tv after a couple of minutes - tv works fine
Hi @SJ70
Try another HDMI lead if you have one.
If the issue continues
Message posted on 22 Dec 2024 03:17 PM
I've tried another cable - no change
I've also done the reset you suggested - again no change, after a few minutes it cuts out briefly before reconnecting
Any other suggestions?
Message posted on 22 Dec 2024 03:34 PM
Hi @SJ70 Just checking that your HDMI lead is not to long (>3m).
Message posted on 22 Dec 2024 03:36 PM
No, it's less than 3 metres it's been the same cable all along and the one I used to change is the same length
Message posted on 22 Dec 2024 03:44 PM
Could be faulty
Tried a different hdmi socket just to eliminate that from your enquiries?
Message posted on 22 Dec 2024 03:45 PM
Yep, tried that too!
Message posted on 22 Dec 2024 04:02 PM
Message posted on 22 Dec 2024 05:38 PM
I have done that too - don't know what else to do!
will have to try Sky
