Discussion topic: Sky q box loads up to Accessibility on Sky Q then freezes.
This message was authored by: Jay8
Cannot make the Sky Q box do anything. Frozen on settings or skip but won't move.
Re: Sky q box loads up to Accessibility on Sky Q then freezes.
@Jay8
try the following...
Unpair their Sky Q remote from the box by holding 4&6
Wait for the remote to flash you should then be able to dismiss the information screen by clicking on Skip & set up later
Hold 1&3 to repair the remote control
If 4&6 does not allow you to clear the information screen, try holding 7&9 to reset the Sky Q remote then hold 1&3 and follow the on-screen setup journey to allow the remote to control your TV.
