Discussion topic: Sky q box keeps losing connection to hub
This message was authored by: Karlos6832
Box kerps lising connection to hub but all other devices work fine
Re: Sky q box keeps losing connection to hub
Hi @Karlos6832
Have you tried completly resetting the Main Q box connection?
