4
This discussion topic has been answered Discussion topic: Sky q box keeps going to a black screen
This message was authored by: Stevj
Cannot watch sky q main box can still watch mini box, as main box keeps going to a black screen
This message was authored by: Laing1 Answer
Re: Sky q box keeps going to a black screen
@Stevj Have you tried rebooting your main Q box ie
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for Stevj
I will certainly give it a try
Avatar for Stevj
That's not sorted the issue
This message was authored by: Chris165
Hi I have a similar issue how did you fix it ?
