Discussion topic: Sky q box keeps freezing, and starts whirring, only turning it off and back on again works
This message was authored by arf180 This message was authored by: arf180
Keeps happening, well annoying. Cleaned all air vents, deleted most recordings off the hard drive, still no good.
Re: Sky q box keeps freezing, and starts whirring, only turning it off and back on again works
Hi @arf180
