Discussion topic: Sky q box keeps disconnecting to ee router
This message was authored by: James711
Tried to reset sky Q.     Then reset broad band with ee.     Connection to broadband router x.     Help
This message was authored by: Addie15
Re: Sky q box keeps disconnecting to ee router
Hi there, @James711.  I’ve escalated your post to our Community Messaging team who will invite you to a private chat shortly and help you with this.
Hi @James711 Try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on?
This message was authored by: Ethanandconor
My Sky Q Box is also disconnecting from Wifi pretty often, even though the home Wifi signal is strong and stable. It is becoming very tiresome for Netflix to drop out and needing to frequently reconnect to Wifi. Box also has a habit of refusing to wake up, needed  a reboot. I think it is past it now and needs replacement.
Update-We are closing this session now due to no further response within 48 hours. If you still need help, please let us know so we can re-escalate this for you. Thanks.
My Sky Q Box is disconnecting from Wifi pretty often (several times a day sometimes), even though the home Wifi signal is strong and stable. It is becoming very tiresome for Netflix to drop out and needing to frequently reconnect to Wifi. Box also has a habit of refusing to wake up, needed  a reboot. I think it is past it now and needs replacement. @Addie15
