Discussion topic: Sky q box isn’t working
This message was authored by Samantha2008 This message was authored by: Samantha2008
My second sky box isn't working , my main sky box is working fine, it is saying there's a problem going your network , the remote will not let me connect with questions it's asking me but the remote will turn the volume up ?
Re: Sky q box isn’t working
Hi @Samantha2008
Try pressing and holding 7 & 9 together on the mini remote until it's led flashes 4 times.
This will set the remote to Infrared which will work with and Q box.
However you must make sure that you are pointing the remote at the Q box as it needs line of sight.
If you can then control the mini
Try completly resetting your mini Bluetooth remote.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the remote led flashes and follow onscreen instructions to re- pair.
