Discussion topic: Sky q box is unable to connect with intenet
This message was authored by: Vickey
The sky q box is not connecting with the Internet. I have still got Internet but  struggling to connect my personal devices to WiFi. I have unplugged the sky q box several times and left it off for more that 5 minutes. Still not connecting
Re: Sky q box is unable to connect with intenet
Hi @Vickey
