Discussion topic: Sky q box is not working. Red light is on. I have changed the batteries in the remote but green ligh
Message posted on 18 May 2023 06:19 PM
Sky q box not turning on. Red light does not change to green. I have put new batteries in remote.
I have checked the cables are secure in back of box.
Message posted on 18 May 2023 06:48 PM - last edited: 18 May 2023 06:49 PM
Re: Sky q box is not working. Red light is on. I have changed the batteries in the remote but green
Have you tried switching the Q box on using the Standby button on the front right of the box (the Amber led)?
If this turns the box on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair
