Discussion topic: Sky q box is not cooencting to internet
This message was authored by: Prem22
Sky q box isnt connecting to internet and freezes everytime we try. Have turned it off and on
Re: Sky q box is not cooencting to internet
Hi @Prem22 Try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on?
Hi @Prem22
