Discussion topic: Sky q box is in standby and tv states no video avaliable
Message posted on 18 Jul 2024 09:38 PM
Tv looks as though it will come on then has no video avaliable on the screen and won't do anything
Message posted on 18 Jul 2024 09:54 PM
Re: Sky q box is in standby and tv states no video avaliable
Hi @Jackie512
If your Q box is it standby then it will not connect to your television set
Message posted on 19 Jul 2024 09:55 AM
Hi @Jackie512
If your Q box still has an Amber led and will not turn on, Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
