Discussion topic: Sky q box in bedroom keeps freezing and volume button on tv remote has stopped working
Message posted on 27 Sep 2023 06:11 PM
Message posted on 27 Sep 2023 06:38 PM
Re: Sky q box in bedroom keeps freezing and volume button on tv remote has stopped working
Hi @Martin29
Reboot the mini as above.
If your mini remote still does not adjust your TV Volume
Try completly resetting your mini Bluetooth remote.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
