Discussion topic: Sky q box constantly disconnecting from virgin broadband
Message posted on 15 Jun 2024 07:23 PM
Can anyone help, I have Virgin Broadband m500 and my sky q box is constantly disconnecting from it. All other devices in my home are connected without problems and i regularly speed check the internet connection when I have disconnections from the q box. Everything is fine. I can't download films or use prime/netflix on sky q as its constantly buffering or disconnecting. I don't experience any such problems if I connect to prime/netflix on the firestick. I've had the sky engineer out who turned off channel optimisation on my virgin router and put the q box in "eco" mode. The disconnections still continue and I'm at the stage where I'm thinking of binning off sky tv completely now. Any help would be appreciated. thanks!
Message posted on 15 Jun 2024 07:25 PM
Re: Sky q box constantly disconnecting from virgin broadband
Hi @DaveM1969
Is the Q box near enough to your router to try Ethernet connection?
Message posted on 15 Jun 2024 07:50 PM
Its not close enough without a very long ethernet cable which I don't have currently. Every other device in the house is working fine on Wifi so I think its got to be the sky q box at fault here. Any setting I could change to resolve the problem on the sky q box?
Message posted on 15 Jun 2024 08:00 PM
Hi @DaveM1969
When the Q box is back up and running complete the following:-
On 3rd party broadband and your router does not have a reset button, reboot it by disconnecting the power lead for 30 secs and then reconnecting.
On 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
Message posted on 15 Jun 2024 08:40 PM
Thanks for the help, I'll try that tomorrow am and update you on how it goes. I appreciate the help!
Message posted on 01 Feb 2025 09:43 PM
Did this work? I'm having the same issues
Message posted on 10 Jul 2025 09:56 PM
Im also having the same problems. Did this work?
Message posted on 29 Oct 2025 02:24 PM
I had the same problem.
Sky engineer changed my box and all was OK for a few hours then it started again.
Screen shows "it looks as though you have no internet" and I can't get Youtube, Netflix etc but I can get them on my smart TV.
Message posted on 29 Oct 2025 02:29 PM
Thanks all, I just don't bother with most of the sky services now via the q box. Smart TV has quick access to netflix, prime, now etc without any stallings/disconnecting issues. Sky not bothered to fix it so after 20 odd years I have not renewed my contract and will leave them soon I think.
