Discussion topic: Sky q box chooses an unknown sky WiFi instead of our house wifi
This message was authored by Leanne310 This message was authored by: Leanne310
Hi. Our main sky q box is automatically disconnecting from our main WiFi and connecting to an unknown sky WiFi.
I go into settings and change if back to our main WiFi but it changes back. It's causing a lot of problems on our 2 mini boxes. I also can't use my Skygo app to watch recordings because I can't connect my phone to this unknown sky WiFi as we don't know the password. Can anyone help please? Thanks
This message was authored by Chodley This message was authored by: Chodley
Re: Sky q box chooses an unknown sky WiFi instead of our house wifi
That's a weird and common symptom of the Q just losing its connection to your router. The SKY##### named network is its internal mesh with the minis.
Leanne310
Thanks for the reply. Is there any way I can block the main sky q box from using the sky internal mesh you mentioned? We really need the q box to connect to our house WiFi so we can connect the minis to the same network. Thanks.
Hi @Leanne310
On 3rd party Broadband,  afraid the minis if using WiFi must connect to the main Q box Sky WiFi mesh.  Minis will not connect to 3rd party routers.
There is no way your main Q box will connect to a Sky WiFi unless you press the WPS button on a Sky router while carrying out a Network reset on the Q box.
First make sure your main Q is corrected connected.
On 3rd party broadband and your router does not have a reset button, reboot it by disconnecting the power lead for 30 secs and then reconnecting.
On 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
Once you get the main Q box connected carry out a Network reset on the minis. Start with the one nearest to the main Q box
When you get the first mini connected then for other minis use WPS on the nearest Q device main Q box or previously connected mini).
Failing all of the above you may need a Sky Q WiFi Booster to position midway between your main Q box and the minis and you will need to contact Sky directly.
It will always use both. Unless the router connection fails as is happening here. A very common issue.
